Posted March 23, 201014 yr comment_313370 Can someone tell me where I can purchase a full set of rubber bushings for a 75 260?I have found many of the poly sets but can't seem to locate the rubber ones.Thanks.Mike, Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/ Share on other sites More sharing options...
March 23, 201014 yr comment_313377 I've never seen the factory-style rubber in preassembled "sets" like the poly bushings come in. I think you'll need to order them all individually. Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313377 Share on other sites More sharing options...
March 24, 201014 yr comment_313488 You might try Z car source-- http://www.zcarsource.com/They sell a complete set for the 240z.Rich Edited March 24, 201014 yr by Rich1 Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313488 Share on other sites More sharing options...
March 24, 201014 yr comment_313490 You might try Z car source-- http://www.zcarsource.com/They sell a complete set for the 240z.RichOuch! I'll wager buying them individually from Nissan would be significantly less than that. Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313490 Share on other sites More sharing options...
March 24, 201014 yr comment_313500 Right you are Arne! This kit does include spindle pins--and some misc. pieces--but the price is still too dear... Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313500 Share on other sites More sharing options...
March 24, 201014 yr comment_313506 I posted this two years ago regarding the oem rubber bushings. The 2006 cost for a full set including spindle pins was about $200 dollars through online dealer (www.buynissanparts.com). I'm shocked if they doubled in price in four years. Here's the link to the original post http://www.classiczcars.com/forums/showthread.php?t=32622 Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313506 Share on other sites More sharing options...
March 24, 201014 yr Author comment_313529 Thanks for the link to Buy Nissan Parts on line. I was not aware of this site.Going through a quick check of their prices as compared to Z Car Source, in general the Nissan site is about 1/2 of the price of Z Car. On top of that they have the entire set of bushings needed whereas the set from Z Car was missing a few which I believe was noted by another member.Based on everything I have read here so far in terms of bushings, I am planning toi use a combination of poly and rubber, which I believe will give me the best compromise of handling as well as ride / noise.I'm still trying to decide which type will go where so any inputs you have would be greatly appreciated.Thanks again for all of the help.Mike. Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313529 Share on other sites More sharing options...
March 24, 201014 yr comment_313544 Mike,Here is the list of the bushing I purchased for my 240ZFRONT CNTRL ARM BUSH 54535-E4100FRT TENSION ROD BUSH 54476-21000FRT SWAY BAR END LINK BUSH 56112-W5000FRT SWAY BAR TO FRAME BUSH 54617-21002RACK BUSH/DRIVERS 54445-E4101RACK BUSH/PASS 54444-E4101FRONT STRUT BUMP STOP 54050-E4101FRONT STRUT MOUNT 54320-E4100REAR CONT ARM INNER BUSH(FRT) 55554-E4100REAR CONT ARM INNER BUSH(REAR) 55555-E4100REAR CONR ARM OUTER 55541-E4100REAR CONR ARM OUTER SPINDLE 55540-N3701REAR CONR ARM OUTER SPINDLE NUT 08912-8421ADIFF MOUNT 55415-E4102REAR STRUT BUMP STOP 54050-E4101REAR STRUT MOUNT 54320-E4100MUSTACHE BAR BUSHING 55476-N4300STEERING COLUMN COUPLER 48073-78500It was very time consuming to locate all the parts, so be patient.Keith Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313544 Share on other sites More sharing options...
March 24, 201014 yr comment_313562 Zed,Thanks for posting the #'s. I am going to bookmark them as I will be replacing them in the near future. Nice to find this information!Leonard Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-313562 Share on other sites More sharing options...
January 4, 201114 yr Author comment_340830 So based on all the help from the forum, I managed to pull together all of the rubber parts that I needed for my front and rear suspension rebuild. (Late 74 260Z).It turns out that some of the parts are no longer available in rubber so I had to settle for poly in those cases, but for the most part you can still get the rubber.Rob at Gastoinian Nissan was very helpful and by far had the best prices as least based on those that I found. He also provided a pretty steep discount where he could, elimianted the handling charge, and brought the shipping charge down to something reasonable. Would definitely do business with him again.I am now in the midst of tearing down the rear end, where I am starting this project. I have both strut assemblies completely out of the car and torn down, including the removal of the spindle pins (Thank you Dave for selling me one of the spindle pin removers that you had. Would never attempt this again without one). My next step will be the removal of the spindle pin bushings, which I understand will be a chore, but I have lots of time to get this completed so I am not too worried about getting it done.However, a few questions have surfaced. My car has the larger (ie taller) strut mount insulators and they are not available from Nissan any longer. It was recommended that I use the ones for the front but these are 1/2 - 3/4 of an inch shorter and I'd prefer not to lower my car by that amount. Has anyone ever done this with the shorter mounts? Also does anyone know of any for sale (other than MSA where they are > $200 each)? If not I will probably just use the old ones which still look to be in pretty good shape.Also, does anyoine have the part number for the strut boots for this car? Finally, I am planning to use ploy bump stops. I assume that these are installed on the strut rod in between the strut tube and the spring carriage which sits on top of the spring. Is this correct.That's about it for now. Will post progress as it moves ahead. Also have lots of pictures if anyone is interested.Also, I did compile a spread sheet of all of the parts necessary for this as well as comparable prices from a number of vendors so if anyone wants a copys of this, just send me a mail I will will send it off to you. Bear in mind that is is for a late model 260Z so some of this will not be applicable to the earlier 240's and 260's.Mike. Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-340830 Share on other sites More sharing options...
January 4, 201114 yr comment_340831 I guess we have a MikeW and a Mike W..... Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-340831 Share on other sites More sharing options...
January 6, 201114 yr Author comment_340998 Yes the two Mike W's was a total accident.When I registered, I used a login name which I use regularly not realizing that there was a MikeW who was already a part of the forumHope this hasn't caused any confusion or inconvenience.Mike. Link to comment https://www.classiczcars.com/forums/topic/35147-rubber-bushing-set/#findComment-340998 Share on other sites More sharing options...
