Posted March 23, 201015 yr comment_313408 I have been tracking down and eliminating sources of gas odor in my 1973 240Z. I have replaced all of the vent hoses and the filler neck. The problem is 90% better but I can still smell a faint gas odor at times. I have been sniffing around and I think the source of the smell is from the gas cap area. I tried tightening the three bolts that lock the cap seat through the filler neck to the body to no effect. The cap looks fine and I tried bending the little tabs in to make it fit more snugly but it still smells. :disappoinIs this standard? It seems to me that the gas cap should seal pretty much 100% of the gas fumes. But before I lay out $55 for a new one I wanted to know if fumes from the filler door is standard on these cars or if I am missing something. Link to comment https://www.classiczcars.com/forums/topic/35155-does-your-cap-stink/ Share on other sites More sharing options...
March 23, 201015 yr comment_313443 Steve, this subject has been discussed ad-nauseaum squared.So much so, that if you search for "gas fumes" or "exhaust smell" (and yes, they are inter-related), you'll max out the search return at 100. Which means there are far FAR more than 100 reply threads. You could spend days reading those replies.To even try, and some will, to summarize it for you; will not pinpoint the specific problem you may be having. Search the archives, check the most often suggested items on your car and you may have the problem fixed. It IS a common problem with these cars.FWIWE Link to comment https://www.classiczcars.com/forums/topic/35155-does-your-cap-stink/#findComment-313443 Share on other sites More sharing options...
March 24, 201015 yr comment_313483 Very well said E. I have fought this issue more than once,and I am sure I will again. I have had these cars for many years and I actually think it is part of owning one. Link to comment https://www.classiczcars.com/forums/topic/35155-does-your-cap-stink/#findComment-313483 Share on other sites More sharing options...
March 24, 201015 yr Author comment_313491 EScanlon said: Steve, this subject has been discussed ad-nauseaum squared.Sorry, I will spend more time with the search function next time. Link to comment https://www.classiczcars.com/forums/topic/35155-does-your-cap-stink/#findComment-313491 Share on other sites More sharing options...
March 25, 201015 yr comment_313627 Steve, you might want to check out the thread from Beandip concerning getting rid of the evaporator tank and the associated gas lines that run through your car. I plan on doing this mod. (I only had gasoline fumes in the interior once when the line hiding behind the rear panel under the hatch split.)http://www.classiczcars.com/forums/showthread.php?t=19034&highlight=fuel+ventThere was another thread somewhere where the poster used a smoke machine inside the car to find air and water leaks. He had some interesting pictures and some interesting areas that needed fixin'. Surprisingly - to me - were that body seams needed caulking! Link to comment https://www.classiczcars.com/forums/topic/35155-does-your-cap-stink/#findComment-313627 Share on other sites More sharing options...
March 25, 201015 yr Author comment_313655 oldhemi said: Steve, you might want to check out the thread from Beandip concerning getting rid of the evaporator tank and the associated gas lines that run through your car. I plan on doing this mod. (I only had gasoline fumes in the interior once when the line hiding behind the rear panel under the hatch split.)http://www.classiczcars.com/forums/showthread.php?t=19034&highlight=fuel+ventThere was another thread somewhere where the poster used a smoke machine inside the car to find air and water leaks. He had some interesting pictures and some interesting areas that needed fixin'. Surprisingly - to me - were that body seams needed caulking!Those are great threads and I have read them and many others several times over the past few weeks. I used the information they contained to eliminate all of my exhaust smell and 90% of the gas smell. On the gas side I have replaced all of the vent hoses, the filler neck and the rubber o-ring around the gas tank sender unit. My gas cap does let out some vapor and I have a new one on order. However the smell is on the inside so I think there is something going on in the interior. My next step is to go back and re-check the the things I have already checked/replaced. It's not a complicated system. I've gotta be missing something small. Link to comment https://www.classiczcars.com/forums/topic/35155-does-your-cap-stink/#findComment-313655 Share on other sites More sharing options...
