Email logins are now active ×
76 280z starts but dies after 30 seconds
Baki 280z
!!HELP!! It runs for 30 secons and dies !!! HELP !!!!
could anybody answer this one ,,, engine starts and it runs for about 20 - 30 seconds and than dies slowly ,,, I got new spark plugs ,cables ,air filter ,fuel pump ,fuel filter, new gas in tank ,,,, if i hold engine on 3000 RPM its working fine and than dies, any suggestions !!!!
i ordered fuel pressure regulator I been told it might be that ,,,any suggestion ?
Edited by Baki 280z
No MAF sensor in a 280z. Check your fuel pressure. If the car has sat for a long period of time there will be sediment in the fuel system which prevents the system from achieving/maintining the proper pressure to run correctly.
When it dies, does it just die instantly like you turned off the key, or does it slowly die over a matter of 10-20 seconds? Case 1 is more electrical suggesting, case 2 is more fuel related. You mentioned slowly, just how slowly? I'de be putting a fuel pressure gauge on there (after fuel filter in engine bay, before fuel rail) and watching what happens at that magic moment before I go spending any more money on parts....
Jim
Edited by zKars
yeah it takes about 5-10 seconds to die slowly , what do you thin could it be fuel pressure regulator? because while is dieing its fighting to stay on ,more i keep doing it , it takes longer time to die when its gets worm
