What coil do you guys recommend for a 75 280? Everything basically stock with mild Isky cam upgrade. Should I just use comparable factory one or hotter?
Thanks for your input!
Bryan
https://www.classiczcars.com/forums/topic/35171-coil-recommendation-75-280z/
If your coil is in good working order I'd stick with that. A mild cam is not going to tax a stock coil. If you need to replace the coil an MSD Blaster should be fine and probably cheaper than OEM. If you ever really need a hotter coil I'd suggest a stock z31 coil. It's as good as any coil out there and much better than most.
