Posted November 7, 200222 yr comment_18494 Does anyone have any experience with wind causing their custom fit car cover to flap against the car and damage the finish? if so, are there any tricks to prevent this flapping?thanks! Link to comment https://www.classiczcars.com/forums/topic/3519-flapping-car-covers/ Share on other sites More sharing options...
November 7, 200222 yr comment_18503 tttz,I've had two custom car covers that were made of a flannel type material and they had plastic grommets at the bottom near the doors for a cable that you pass under the car and a lock into place to keep it from blowing off and to keep people from taking it.If yours doesn't have this setup, try finding the plastic grommets at a fabric or hardware store. You can probably use bungie cords if your'e not concerned about theft.Good luck,Rob Link to comment https://www.classiczcars.com/forums/topic/3519-flapping-car-covers/#findComment-18503 Share on other sites More sharing options...
November 7, 200222 yr Author comment_18504 Originally posted by tttz Does anyone have any experience with wind causing their custom fit car cover to flap against the car and damage the finish? if so, are there any tricks to prevent this flapping?thanks! Thanks Rob,Did you experience any damage to the paint from windy conditions? Link to comment https://www.classiczcars.com/forums/topic/3519-flapping-car-covers/#findComment-18504 Share on other sites More sharing options...
November 7, 200222 yr comment_18507 No, not really. I lived in Orange Co. and Ventura, Ca. when I used them and it does'nt get very windy in those places.As I recall, when I lived in Vallejo and worked in San Francisco, up your way, it got REALLY windy at times!If you're going to secure the cover underneath, make sure you since it up tight and you should be OK.Rob Link to comment https://www.classiczcars.com/forums/topic/3519-flapping-car-covers/#findComment-18507 Share on other sites More sharing options...
