Recently Browsing 0
Can you tell me if the dist.vac on the charcoal canister goes the a T that goes to the distributor and a port under the airflow meter and if the purge line on the charcoal canister goes to the port on the top side of the intake manifold? Does the vac. line on the heat and a/c cause the engine to run poorly if not correctly connected?
Edited by gas4765
https://www.classiczcars.com/forums/topic/35227-vac-lines-and-charcoal-can/Share on other sites
