Posted March 28, 201015 yr comment_313981 As topic states, what are the major differences between these three cars and which would you say is a better vehicle and why?Thanks alot again guys Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/ Share on other sites More sharing options...
March 28, 201015 yr comment_313986 Major differences...240Z = 2.4 L Engine260Z = 2.6 L Engine280Z = 2.8 L EngineBetter vehicle? To each it's own I think, although the '73 240Z did come out with some crappy flat top carburetors that many people replace. Late 240Z, 260Z, and 280Z had bigger bumpers in the front and back, as well as different vehicle weight.http://www.zhome.comExcellent source of Z information. You'd be surprised how much the 240Z itself changed from 1970-1973 models. Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-313986 Share on other sites More sharing options...
March 28, 201015 yr comment_314031 AND since you are posting from Barbados, you may want to consider that much of the information you'll find here and zhome is SPECIFIC to the US market.Not sure about Barbados, but you may have had more than ONE year of 260's, unlike the US which only had them in 75.2¢E Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-314031 Share on other sites More sharing options...
March 28, 201015 yr comment_314034 The 260Z was a 1974 model in the U.S. 1975 - 1978 models were 280Z's The big differences here were the extra emissions controls on the 73-74 cars, and the introduction of fuel injection in 1975. Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-314034 Share on other sites More sharing options...
March 28, 201015 yr Author comment_314035 Ok thanks Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-314035 Share on other sites More sharing options...
March 28, 201015 yr comment_314051 280z's were fuel injected, an added benefit. Not sure if some later models(77 and 78) had 5 speed trannys, but some had the R200 rearend instead of the R180, a little bit stronger. I just hated the bumpers on the 280z's. The thin ones looked so much better. Oh, and 77 and 78's had vented hoods. Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-314051 Share on other sites More sharing options...
April 4, 201015 yr comment_314842 What about body parts are there comparable Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-314842 Share on other sites More sharing options...
April 4, 201015 yr comment_314843 What about body parts are there comparableLargely yes. Fenders, hoods, and hatches although not all exactly the same are perfectly interchangeable. Doors are not. Bumpers are different (got much larger and rubbery starting on late year 260Z's) but can be retro-fitted with a little work. 5 Speed showed up as an option on the 280Z but I don't believe was standard during any model year.Read Zhome.com. It's all there. Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-314843 Share on other sites More sharing options...
July 12, 201014 yr comment_325019 I don't know if I'm missing it, but I don't see anything on Zhome for topics on the 260Z. I wanted to know the car weight and compare to other S30's, but I am having trouble finding it through search. Can someone help me, please? Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-325019 Share on other sites More sharing options...
July 12, 201014 yr comment_325041 Rough estimate...Early 240Zs weighed in at about 2400 lbs. They porked up a bit each year until the 260Z in '74 when they weighed approx 2600 lbs. The 280Zs were close to 2800 lbs. Actual numbers are out there, but I'm too lazy to find 'em... but these are close. Link to comment https://www.classiczcars.com/forums/topic/35229-what-are-the-main-difference-between-the-240z-260z-280z/#findComment-325041 Share on other sites More sharing options...
