Posted March 29, 201015 yr comment_314214 Recently I decided to convert my 77 280Z transistor ignition over to the GM HEI module. I used my existing distributor and just removed the original transistor ignition and ballast resistor and installed the GM module. I used a Pertronix Flame Thrower II (.6 Ohms) coil. I followed instructions for connecting the wiring from the ballast resistor. Started the car and it ran great. The only problem is that the tach doesn't move unless I gun the engine and then it jumps up to 2-3k then just drops to zero. A member on another forum suggested removing the resistor located on the pax foot well. I disconnected it and installed a jumper wire. Same thing, car runs great just no tach. Any suggestion would be welcomed. Thanks Link to comment https://www.classiczcars.com/forums/topic/35253-gm-hei-now-no-tach/ Share on other sites More sharing options...
March 30, 201015 yr comment_314262 I am not sure that the HEI module can manage the 0.6Ω Flame Thrower II coil without a ballast resistor, the switching current would be quite to high for the HEI module to handle. Try introducing the ballast resistor inbetween the +12 wire and coil (+), does the tacho work then? Do you have a three or four wire tach? Link to comment https://www.classiczcars.com/forums/topic/35253-gm-hei-now-no-tach/#findComment-314262 Share on other sites More sharing options...
March 30, 201015 yr comment_314286 Adrian, it's a 280Z, he will have a 3 wire. Link to comment https://www.classiczcars.com/forums/topic/35253-gm-hei-now-no-tach/#findComment-314286 Share on other sites More sharing options...
March 30, 201015 yr comment_314302 Thanks, i missed that. Its still interesting to see the result with the ballast resistor added, this mod would lower the kickback voltage send to the tach. Link to comment https://www.classiczcars.com/forums/topic/35253-gm-hei-now-no-tach/#findComment-314302 Share on other sites More sharing options...
March 30, 201015 yr Author comment_314349 I was thinking maybe just replace the .06 ohm coil with a Flamethrower 1.5 or 3.0 ohm unit? What do you think? Link to comment https://www.classiczcars.com/forums/topic/35253-gm-hei-now-no-tach/#findComment-314349 Share on other sites More sharing options...
March 31, 201015 yr comment_314400 A Flamethrower 3Ω coil should be safe. Try out the resistor in line with the Flamethrower II coil before you spend money. With the resistor in line you have a ~2Ω coil, that should be a good test to see if the tach works. Link to comment https://www.classiczcars.com/forums/topic/35253-gm-hei-now-no-tach/#findComment-314400 Share on other sites More sharing options...
March 31, 201015 yr Author comment_314486 Just for giggles I hooked up a 1.5 Ohm Flamethrower that I had and the tach worked. So if I want to use the .6 ohm Flamethrower II looks like I need a 1 ohm resistor inline. Thanks for all the input. Link to comment https://www.classiczcars.com/forums/topic/35253-gm-hei-now-no-tach/#findComment-314486 Share on other sites More sharing options...
