GM Hei now no tach
chiefmd
Recently I decided to convert my 77 280Z transistor ignition over to the GM HEI module. I used my existing distributor and just removed the original transistor ignition and ballast resistor and installed the GM module. I used a Pertronix Flame Thrower II (.6 Ohms) coil. I followed instructions for connecting the wiring from the ballast resistor. Started the car and it ran great. The only problem is that the tach doesn't move unless I gun the engine and then it jumps up to 2-3k then just drops to zero. A member on another forum suggested removing the resistor located on the pax foot well. I disconnected it and installed a jumper wire. Same thing, car runs great just no tach. Any suggestion would be welcomed. Thanks
I am not sure that the HEI module can manage the 0.6Ω Flame Thrower II coil without a ballast resistor, the switching current would be quite to high for the HEI module to handle.
Try introducing the ballast resistor inbetween the +12 wire and coil (+), does the tacho work then? Do you have a three or four wire tach?
A Flamethrower 3Ω coil should be safe. Try out the resistor in line with the Flamethrower II coil before you spend money. With the resistor in line you have a ~2Ω coil, that should be a good test to see if the tach works.
  • Who's Online   2 Members, 1 Anonymous, 767 Guests (See full list)
