Posted April 2, 201015 yr comment_314629 Trying to put a 77 diff into a 75 body using the 77 crossmember with a solid diff mount. The problem is the centering bolt is too far forward by an inch. I can't locate this issue in the searches (too much information, nothing specific). Any suggestions on what might be wrong? Any chance the mount itself is wrong? I am assuming:finger:that the diff is physically the same in the 75 as is in the 77. Thanks! Leonard Link to comment https://www.classiczcars.com/forums/topic/35298-77-diff-into-75-body/ Share on other sites More sharing options...
April 2, 201015 yr comment_314632 Both cars should have a R200 as you may know but I never heard of different style mounts or cross members for the R200 in S30Z's. You sure nothings got tweaked or twisted in the 75 or77 bringing that center hole off by a inch due to torque/body twist from burn outs? Does the 77 cross member appear similar in shape to the 75 cross member? Edited April 2, 201015 yr by WingZr0 Link to comment https://www.classiczcars.com/forums/topic/35298-77-diff-into-75-body/#findComment-314632 Share on other sites More sharing options...
April 2, 201015 yr Author comment_314650 I thought it should have been a direct swap. It belongs to the guy who is painting my car and since I am still recovering from rotator surgery, all I can do is watch. Nothing seems out of the ordinary. We are thinking the solid diff mount is the problem, that it was meant for a different application or ?? We will try to find an oem style today and see if it is different. The old one was decayed and tossed. It was mind boggling last night as everything seemed to work right up until it didn't. As soon as we can get his car out of the way (major suspension work), I can get my car in for the shell to be painted. It isn't about him, it's about me LOLLOLLOL Link to comment https://www.classiczcars.com/forums/topic/35298-77-diff-into-75-body/#findComment-314650 Share on other sites More sharing options...
April 2, 201015 yr comment_314675 HaHa, yeah, get that Z back on the road . Just so I'm on same page what do you mean by solid diff mount? You mean as in locked differential or a mount that use no bushings? Sounds like you might be right though, give MSA a quick ring and ask if they ever heard of a different style cross member or mount as your experiencing if no one else chimes in on it. Edited April 2, 201015 yr by WingZr0 Link to comment https://www.classiczcars.com/forums/topic/35298-77-diff-into-75-body/#findComment-314675 Share on other sites More sharing options...
April 2, 201015 yr comment_314677 They should be the same. I would suggest you trash your solid diff mount and get a Ron Tyler mount. It's better in every respect.He didn't flip the mustache bar by chance, did he? It should be behind the suspension. Link to comment https://www.classiczcars.com/forums/topic/35298-77-diff-into-75-body/#findComment-314677 Share on other sites More sharing options...
April 4, 201015 yr Author comment_314832 Jon,You were dead on. All we had handy was the pictures from black dragon. They show it turned the other way. Inspection of the other Z's in my yard showed it the opposite direction. Thanks for the tip!Leonard Link to comment https://www.classiczcars.com/forums/topic/35298-77-diff-into-75-body/#findComment-314832 Share on other sites More sharing options...
