Posted April 6, 201015 yr comment_315069 Im having a noise from tranny like a metal to metal whining noise..when on idle it make noise but if i step on the clutch its gone I just recently change my clutch to Centerforce II..You think my new throwout bearing gone bad, input shaft bearing or clutch mis-adjusted? but other than that they all shifts fine on all gears with no noise..pls help.. Link to comment https://www.classiczcars.com/forums/topic/35357-tranny-noise/ Share on other sites More sharing options...
April 6, 201015 yr comment_315074 Sounds more like a throw-out bearing issue than a transmission problem. Mine has a similar issue but it's not particularly bothersome. A mild noise when idling in neutral goes away when depressing the clutch. Not noticeable at all when driving.... Link to comment https://www.classiczcars.com/forums/topic/35357-tranny-noise/#findComment-315074 Share on other sites More sharing options...
April 6, 201015 yr comment_315075 if it goes away when you step on the clutch, it's either an input shaft bearing or one of the two countershaft bearings. Not a release bearing or clutch problem. Link to comment https://www.classiczcars.com/forums/topic/35357-tranny-noise/#findComment-315075 Share on other sites More sharing options...
April 6, 201015 yr Author comment_315081 damn sound like rebuild.. Link to comment https://www.classiczcars.com/forums/topic/35357-tranny-noise/#findComment-315081 Share on other sites More sharing options...
