Posted
Im having a noise from tranny like a metal to metal whining noise..when on idle it make noise but if i step on the clutch its gone I just recently change my clutch to Centerforce II..You think my new throwout bearing gone bad, input shaft bearing or clutch mis-adjusted? but other than that they all shifts fine on all gears with no noise..pls help..
https://www.classiczcars.com/forums/topic/35357-tranny-noise/
Sounds more like a throw-out bearing issue than a transmission problem. Mine has a similar issue but it's not particularly bothersome. A mild noise when idling in neutral goes away when depressing the clutch. Not noticeable at all when driving....
