May 3, 200420 yr comment_79412 Thanks All,I got them out yesterday using the drill method, brute force and hacksaw. All virtually painless - gasp!!Cheers,Rob Link to comment https://www.classiczcars.com/forums/topic/3539-front-control-arm-bush-question/?&page=2#findComment-79412 Share on other sites More sharing options...
May 3, 200420 yr comment_79413 Attaboy Rob, we knew you could do it. Z folks can do anything!!!Let us know how she drives when you get her done.:classic: Chris Link to comment https://www.classiczcars.com/forums/topic/3539-front-control-arm-bush-question/?&page=2#findComment-79413 Share on other sites More sharing options...
May 16, 200420 yr comment_81299 Hi All, Managed to finish up the front suspension this weekend. Little bit knackered now but good to have got it all done. Just need to get a brake pedal back before I can try her out again - then of course start planning the rear swap, whoopee! Cheers, Rob Link to comment https://www.classiczcars.com/forums/topic/3539-front-control-arm-bush-question/?&page=2#findComment-81299 Share on other sites More sharing options...
May 16, 200420 yr comment_81307 Good to see someone actually putting his jack stands in the correct place! Even a piece of wood to protect the metal:D , Nice! Link to comment https://www.classiczcars.com/forums/topic/3539-front-control-arm-bush-question/?&page=2#findComment-81307 Share on other sites More sharing options...
May 16, 200420 yr comment_81324 You put in a set of RUBBER T/C bushings too,Right?? Link to comment https://www.classiczcars.com/forums/topic/3539-front-control-arm-bush-question/?&page=2#findComment-81324 Share on other sites More sharing options...
May 17, 200420 yr comment_81375 Originally posted by Ed Good to see someone actually putting his jack stands in the correct place! Even a piece of wood to protect the metal:D , Nice! Lucky guess Originally posted by Originally posted by Ed You put in a set of RUBBER T/C bushings too, Right?? I swapped everything up front I could find with urethane bushings, control arm, radius/tension rod, sway bar drop links, steering rack and coupler. Hopefully they should last a few more miles Cheers, Rob Link to comment https://www.classiczcars.com/forums/topic/3539-front-control-arm-bush-question/?&page=2#findComment-81375 Share on other sites More sharing options...
June 4, 200420 yr comment_83933 black beaut - in the pic you attached to your post does the suspension have a "bumpsteer spacer" installed, and if so where did you source this from ??? Link to comment https://www.classiczcars.com/forums/topic/3539-front-control-arm-bush-question/?&page=2#findComment-83933 Share on other sites More sharing options...
