Posted April 8, 201015 yr comment_315444 my 78 280z recently started to lag when starting, it would take 2-3 turns of key to start. But know it just dosent start. If I use starting fluid it starts right up. Once the car starts it dosent turn off, but the car feels a little shakey in first unless I really push on it. A friend told me it could be a bad injector if so how can I check witch one. has anyone had a similar problem. Link to comment https://www.classiczcars.com/forums/topic/35394-what-could-be-the-problem-injectors-help/ Share on other sites More sharing options...
April 9, 201015 yr comment_315466 check the fuel pressure, that is you're first step. Link to comment https://www.classiczcars.com/forums/topic/35394-what-could-be-the-problem-injectors-help/#findComment-315466 Share on other sites More sharing options...
