Posted April 9, 201015 yr comment_315541 Ok heres the deal i got this car a while ago from a customer who wanted a basic tune-up and a few other things then it turned into well its not running blah blah blah He finally sent me the transistor and ecm and so on it wouldnt fire cause we arent getting gas but it fired when ether was spayed in the tbI check fuel pump leads no power I test pump it fail I just got a new pump and its mounted SO my problem isare the relays the only thing that can stop power to the pump there was a hot line wired into the pump wich i shorted not knowing it was hot now i cant locate a fuse or source for that Im kinda screwed i want it running so i can get the car out of my garageAny insight or help would be great Link to comment https://www.classiczcars.com/forums/topic/35405-fuel-pump-help/ Share on other sites More sharing options...
April 9, 201015 yr comment_315544 Different years use different power control to the pump. Link to comment https://www.classiczcars.com/forums/topic/35405-fuel-pump-help/#findComment-315544 Share on other sites More sharing options...
April 9, 201015 yr Author comment_315547 im at a stand still this sucks howell back to the drawing board time to read up Link to comment https://www.classiczcars.com/forums/topic/35405-fuel-pump-help/#findComment-315547 Share on other sites More sharing options...
April 9, 201015 yr comment_315549 check the FSM yet? I believe there is a wire from the air regulator that controls the fuel pump relay, test fuseible links? Link to comment https://www.classiczcars.com/forums/topic/35405-fuel-pump-help/#findComment-315549 Share on other sites More sharing options...
April 9, 201015 yr Author comment_315550 checked the one on the bracket i didnt see another Ill go double check its a 76 280z btw think i forgot to put that in there Link to comment https://www.classiczcars.com/forums/topic/35405-fuel-pump-help/#findComment-315550 Share on other sites More sharing options...
April 11, 201015 yr comment_315700 I went to start my car and it backfired slightly and now it just turns over and wont start. I pulled out a plug, im getting spark and fuel. I took off the valve cover and the timing chain is fine. Is there a sensor or something preventing my car to fire up? Anyone have any ideas, please reply. thanx Link to comment https://www.classiczcars.com/forums/topic/35405-fuel-pump-help/#findComment-315700 Share on other sites More sharing options...
April 11, 201015 yr comment_315702 checked the one on the bracket i didnt see another Ill go double check its a 76 280z btw think i forgot to put that in there76 uses a contact switch in the AFM to kill power to the pump when the engine is not running. If you take the black side cover off, you'll see it, it closes when the AFM flap opens a few degrees. Move the counterweight and you can see it working.I have had the contacts get dirty and not close. Had to clean them up with a match book striker, they're small. Link to comment https://www.classiczcars.com/forums/topic/35405-fuel-pump-help/#findComment-315702 Share on other sites More sharing options...
