Posted April 11, 201015 yr comment_315717 just installed new flywheel,clutch,pressure plate, release bearing,When i let up the cluch im getting a bouncing and tremble in the car,like it viberates instead of a smooth shift, anybody know why this is happening? Link to comment https://www.classiczcars.com/forums/topic/35429-clutch-problem/ Share on other sites More sharing options...
April 12, 201015 yr comment_315728 Sounds like it's either out of align or the pressure plate wasn't torqued properly. Just a guess. Did you use an alignment tool when you put it together? Link to comment https://www.classiczcars.com/forums/topic/35429-clutch-problem/#findComment-315728 Share on other sites More sharing options...
April 12, 201015 yr comment_315736 Did you take care to make sure all the friction surfaces were perfectly clean? A little oil in the wrong place will cause the symptoms you describe.Steve Link to comment https://www.classiczcars.com/forums/topic/35429-clutch-problem/#findComment-315736 Share on other sites More sharing options...
April 12, 201015 yr Author comment_315752 No oil on anything I used rubber gloves and yes i used an alignment tool . I had the same problem before i changed anything. Just wondering if the bushing in the transmission support could cause this seeing they are 32 years old. Feels like a bad viberation. Link to comment https://www.classiczcars.com/forums/topic/35429-clutch-problem/#findComment-315752 Share on other sites More sharing options...
