Posted April 11, 201015 yr comment_315719 I need to get a window regulator for my 1977 280Z, found one on ebay but it says it came out of a 2+2 model. I was wondering if that would make it too large? Im not familiar with the 2+2 models, so i wanted to know if the '77 2+2 window regulator would fit in my '77 coupe. Thanks guys!!! Link to comment https://www.classiczcars.com/forums/topic/35430-does-a-22-window-regulator-fit-a-coup/ Share on other sites More sharing options...
April 12, 201015 yr comment_315722 I checked an old MSA electronic catalog I have.30-2224 77-78 Coupe,74-78 2+2, Left [A]30-2225 77-78 Coupe,74-78 2+2, Right $143.83 5lbs.It looks like it should work. Link to comment https://www.classiczcars.com/forums/topic/35430-does-a-22-window-regulator-fit-a-coup/#findComment-315722 Share on other sites More sharing options...
April 12, 201015 yr comment_315724 Good opportunity to plug the Club CD.... that would allow you to determine this sort of thing yourself.It says it should be ok. E Link to comment https://www.classiczcars.com/forums/topic/35430-does-a-22-window-regulator-fit-a-coup/#findComment-315724 Share on other sites More sharing options...
April 12, 201015 yr Author comment_315731 Awesome!! The guy on ebay said it wouldnt work but i figure what the hell i may as well go for it. Thank for the responses guys, if anyone else has an answer let me know! I appreciate it Link to comment https://www.classiczcars.com/forums/topic/35430-does-a-22-window-regulator-fit-a-coup/#findComment-315731 Share on other sites More sharing options...
