June 26, 20241 yr comment_666805 BTW, I started putting the resurrected hoses in today and a little trick for those that need it. Almost every braided hose I've come across has little "frays" on the end like this what i do is wrap the end in this cloth electrical tape once you put the tape around its really easy to trim those loose hairs with a standard scissor and you aren't struggling with the braids unwrapping while you do it. the color is a perfect match and once the clamps go on you cant even see it Link to comment https://www.classiczcars.com/forums/topic/35462-datsun-240z-braided-heater-hose-set-available/?&page=3#findComment-666805 Share on other sites More sharing options...
June 26, 20241 yr comment_666818 You can also use a lighter, the cloth wrap has some percentage of synthetic material in it so seals it self up with the heat. Link to comment https://www.classiczcars.com/forums/topic/35462-datsun-240z-braided-heater-hose-set-available/?&page=3#findComment-666818 Share on other sites More sharing options...
June 26, 20241 yr comment_666819 Thanks granny good to know, will try that next time. Just not on the old fuel hoses 🤣 Link to comment https://www.classiczcars.com/forums/topic/35462-datsun-240z-braided-heater-hose-set-available/?&page=3#findComment-666819 Share on other sites More sharing options...
