Posted April 17, 201014 yr comment_316173 on a stock 2.4 block with E88 head will the valves hit the pistons if you rotate the crank indepently from the cam? Link to comment https://www.classiczcars.com/forums/topic/35497-stock-240-piston-valve-clearance/ Share on other sites More sharing options...
April 17, 201014 yr comment_316194 Yes they will, interference engine. Link to comment https://www.classiczcars.com/forums/topic/35497-stock-240-piston-valve-clearance/#findComment-316194 Share on other sites More sharing options...
April 17, 201014 yr Author comment_316226 Thanks Link to comment https://www.classiczcars.com/forums/topic/35497-stock-240-piston-valve-clearance/#findComment-316226 Share on other sites More sharing options...
