'72 240z- triple 45 dcoe weber carbs
Hi, I have a problem with my idle. When the car is warmed up and sitting and idling it holds at about 500 rpm just fine, but sometimes when I drive it and come to a stop it'll slowly stumble to about 300 rpm and then die on me. I'm not too sure that's going on.
Help!
Thanks
Tyler
Edited by Esc8p2NeverLand
https://www.classiczcars.com/forums/topic/35521-car-dies-at-idle-sometimes/
Just a thought to share. I had a problem such as yours and found that I had a vacuum leak
at the brake booster. Each time I came to a stop my car would want to die. I replaced it and problem solved.
Edited by 2-4-T-Z-MAN
I've had similar issues with loose ignition wires at the coil/resistor.
I've also had that happen with my recent dashpot sticking issues, but if the car drives fine then I doubt its anything to do with that.
When I had a battery in the car that couldn't hold a charge properly it also would die if left idling for a few minutes, probably due to voltage drop.
I guess the first thing to check is if it's ignition or fuel related...
I'd go in with a can of carb cleaner and adress any areas that might show as a vacuum leak. With the engine running,the speed should increase as the carb cleaner gets drawn into the engine. You want to check hoses and mounting surfaces like between manifold and head....
I'm new to z-cars so please forgive me if this is a normal thing for them- When driving at night and the car is at idle, the lights dim quite a bit, but when revved the lights brighten up again. Could this be a cause? Maybe bad battery or alternator?
Well it's not normal but it seems normal to early Z's. Problem is low output of alternator at idle, one cure is to replace with later model 60 amp interally regulated alternator, MSA has a kit available as well as zspecialties.
I haven't had a chance to test vacuum leaks with carb cleaner, but I did a visual inspection and nothing seems out of place and in need of repair.
NOW I CAN'T GET THE DAMN THING TO IDLE. I have to set the idle high to about 1500 and it'll run for about 5 minutes then it'll just drop off and flat out die.
So frustrated!
I tried readjusting the throttle linkage. I took the arms off and tried them at three different spots. Originally it was hooked up to the middle hole on the lever.
So after getting really frustrated, I just rechecked, retightened, retuned my carbs. I Pulled vacuum lines off, pushed them back on tightly and ziptied them. I redid the arms on the linkage. I retuned the idle mixture and idle. Here's what I got.
-Idle at 850 rpm. It drops to about 650-700 rpm with lights, fan, and radio on.
-Idle screw down 3/32 of a turn past touching
-Mixture screws set to 1 1/4 turn out all the way across
For reference the carbs are:
45 DCOE
36mm choke
155 Main Jets
170 Corrector Jets
55 F8 Idle Jets
F16 Emulsion tubes
On my previous tune last night where I microtuned with the ColorTune Tool for the mixture I got for the turns out
#1- 1 1/4
#2- 1/1/4
#3- 3/4
#4- 1/1/4
#5- 3/4
#6- 3/4
The car drove wonderfully, but I could not hold an idle at stop. Maybe due to incorrect jet sizing?
Let's hope the idle holds fine tomorrow!
Tyler
So now something odd is happening with the idle. So when I start it up, I have to play with the gas for about 3 minutes until the temperature probe moves on the dash, then if I let go of the gas it'll stumble low to about 400 rpm and die.
On the other hand, if I pop the hood and manually give the throttle a little "blip" it'll go to about 850 rpm and idle great.
So I thought maybe I have to just give it a tap or two of the gas pedal to recreate the same thing. NO! It doesn't work. If I then proceed to pop the hood and "blip" it again it'll idle fine.
Any ideas?
