Posted April 19, 201015 yr comment_316377 I've got a new set of Eibachs, and they are pretty light on the destructions. Two of them are shorter and have tighter coils that change to wider near the ends, and the other two are longer and are more linear in design.Also, which way up should I install these? Tighter coils on the bottom and wider towards the top, or tighter coils up top and wider on the bottom?I should be able to get a picture up at lunch. Link to comment https://www.classiczcars.com/forums/topic/35529-eibach-coils-which-are-front-and-which-are-back/ Share on other sites More sharing options...
April 19, 201015 yr comment_316382 Definately a couple of threads on this issue. Might be differing points of view on what is top an what is bottom though. Link to comment https://www.classiczcars.com/forums/topic/35529-eibach-coils-which-are-front-and-which-are-back/#findComment-316382 Share on other sites More sharing options...
April 19, 201015 yr comment_316386 The Eibach factory says #s ending in 001 front, 002 rear. Letters and #s right side up.Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/35529-eibach-coils-which-are-front-and-which-are-back/#findComment-316386 Share on other sites More sharing options...
April 19, 201015 yr comment_316390 That`s how I installed mine. Front looks really tall though - I intend to cut mine befor the season starts. Link to comment https://www.classiczcars.com/forums/topic/35529-eibach-coils-which-are-front-and-which-are-back/#findComment-316390 Share on other sites More sharing options...
April 19, 201015 yr Author comment_316397 Found the threadAnswers are in hyahttp://www.classiczcars.com/forums/showthread.php?t=31940&highlight=eibach+front+backwhile I'm at it, I have four tokico blues. Does it matter which are front and which are back? I think two of them might have an extra bit welded onto the end. Edited April 19, 201015 yr by Z-Luke Link to comment https://www.classiczcars.com/forums/topic/35529-eibach-coils-which-are-front-and-which-are-back/#findComment-316397 Share on other sites More sharing options...
April 21, 201015 yr comment_316703 The fronts come from Tokico with a section of pipe pushed onto the bottom so they will fit tight in the stock front strut tube. Link to comment https://www.classiczcars.com/forums/topic/35529-eibach-coils-which-are-front-and-which-are-back/#findComment-316703 Share on other sites More sharing options...
April 21, 201015 yr comment_316704 The fronts come from Tokico with a section of pipe pushed onto the bottom so they will fit tight in the stock front strut tube.You mean the rears. The rear strut tubes are longer, the struts are the same. So to fit the longer tube they press a section of pipe onto the bottom.Short springs in front, if you have progressive springs, tight winds at the top reduces unsprung weight marginally which is a good thing, but in practice probably makes no difference. Link to comment https://www.classiczcars.com/forums/topic/35529-eibach-coils-which-are-front-and-which-are-back/#findComment-316704 Share on other sites More sharing options...
