Posted April 24, 201014 yr comment_317126 I Need to know the bolt size of the bolts that hold the thermostat housing to the head. I broke mine when taking it off. Thanks in advance for your help.Manny Link to comment https://www.classiczcars.com/forums/topic/35632-bolt-size/ Share on other sites More sharing options...
April 25, 201014 yr comment_317135 M8 1.25 x 35mmm8 1.25 x 70mmLet me know how the extraction goes. I have a couple spare E31's with the same problem.John Link to comment https://www.classiczcars.com/forums/topic/35632-bolt-size/#findComment-317135 Share on other sites More sharing options...
April 25, 201014 yr comment_317136 Hi,m8 x 1.25 is the size. Im not sure of the length. Link to comment https://www.classiczcars.com/forums/topic/35632-bolt-size/#findComment-317136 Share on other sites More sharing options...
April 25, 201014 yr comment_317148 Generally, welding a bolt out is the quickest way to remove a broken bolt or stud, especially if broken off below the surface. Full Disclosure: I retired from this company 4 years ago. Link to comment https://www.classiczcars.com/forums/topic/35632-bolt-size/#findComment-317148 Share on other sites More sharing options...
