Posted April 26, 201014 yr comment_317304 doses any one know where i can get or do they make a intake for one weber carb? ( for my 240 z) i have a weber 38 outlaw that is way too much for my samuari 4 banger and my S U 's are getting old and crankie thanks mike in atlanta Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/ Share on other sites More sharing options...
April 27, 201014 yr comment_317315 Never heard of one, Mike. The term "single Weber" just isn't as exotic as "dual" or "triple" Webers. I'd get ZTherapy's DVD on SUs and go from there. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317315 Share on other sites More sharing options...
April 27, 201014 yr Author comment_317318 check this one out Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317318 Share on other sites More sharing options...
April 27, 201014 yr comment_317344 I have a couple of single carbie intakes from 260/280C/Skyline L6 engines. No idea whether you could adapt a weber to them though. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317344 Share on other sites More sharing options...
April 27, 201014 yr comment_317362 The Holly conversion has had mixed reviews, knapper. Use the "search" function to find the good, bad and the ugly....You may want to take a look at hybridz.org. They might have some stuff on it as well. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317362 Share on other sites More sharing options...
April 27, 201014 yr Author comment_317413 thats why i want to use a weber 38 the holly is way too much mk Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317413 Share on other sites More sharing options...
April 28, 201014 yr comment_317439 Hmmm. You wish to use a single 38mm Weber? Is that just ONE 38mm Weber for the six cylinders?Help us out here... Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317439 Share on other sites More sharing options...
April 28, 201014 yr comment_317442 Just a guess from someone who typically doesn't do a lot of hot rodding, but since the stock SUs have two 46mm throats, and that even a pair of Weber DGV's is only considered to be stock replacement, I suspect that a single Weber with two 38mm throats would not be a performance upgrade. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317442 Share on other sites More sharing options...
April 28, 201014 yr comment_317446 I wouldn't think so, Arne, but I was reading ONE carb, not two from his original post. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317446 Share on other sites More sharing options...
April 28, 201014 yr comment_317457 It looks like the one you posted a picture of is from Arizona Z car, but it has a Holley bolt pattern and recommends using a Holley 390 CFM carb http://www.arizonazcar.com/manifold.html.Here is one for sale on ebay now http://cgi.ebay.com/ebaymotors/1970-83-Datsun-Z-car-4-Barrel-Carb-Manifold-EC-NR-_W0QQcmdZViewItemQQfitsZModelQ3a240Q5AQQhashZitem3a5a4e37deQQitemZ250623178718QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories. Currently at $5.50 with no reserve and about 5 days to go.-Mike Edited April 28, 201014 yr by Mike B typo Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317457 Share on other sites More sharing options...
April 28, 201014 yr Author comment_317485 thats correct one weber i could always get an adapter to the arz intake i'm not trying to make her a race car i think the one 38 weber would feed her well thanks just put a solex one barrel on my gl 1000 honda works great Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317485 Share on other sites More sharing options...
April 28, 201014 yr comment_317512 If you wan't to go with that solution, this might be interesting manifold on ebay Germany Chris Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/#findComment-317512 Share on other sites More sharing options...
