April 28, 201014 yr comment_317546 If a 38 Weber will bolt on, that manifold seems to be the one he needs.... Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-317546 Share on other sites More sharing options...
May 3, 201014 yr Author comment_318172 thanks chris 75 bucks shipped looks like what i want mk Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-318172 Share on other sites More sharing options...
May 3, 201014 yr comment_318174 So did you buy it? may i ask for what reason you want to down grade you car with that solution.Chris Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-318174 Share on other sites More sharing options...
May 4, 201014 yr Author comment_318264 we will see i think the weber will do the job i realy think the holly is too much mk Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-318264 Share on other sites More sharing options...
June 10, 201014 yr Author comment_322226 the carb is mounted and the big day is about here will it run ? mk Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-322226 Share on other sites More sharing options...
June 10, 201014 yr comment_322229 I suspect it will run, just not sure that single carb is enough to allow it to run well.... Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-322229 Share on other sites More sharing options...
June 11, 201014 yr comment_322230 I'm recalling way back they ran a single barrel carb on the old stovebolt 6 cyl Chevy motors and they ran...... They didn't do anything particularly exciting performance wise but they ran. Seems like cylinders 1&6 were lean most of the time. Oh well, that's why they have multiple starting gates at the horse races...... so all the horses can run. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-322230 Share on other sites More sharing options...
June 11, 201014 yr comment_322303 I have a stovebolt in my '54 pickup with one single barrel carb. This motor will probably rev all the way up to 2,800 rpm-definitely not a performance setup. Judging by the plugs I'd guess that 1&6 definitley run hotter. It does seem like a long distance for the fuel to travel to get to the ends. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-322303 Share on other sites More sharing options...
June 11, 201014 yr comment_322307 That thing is gonna fall on its face over 2 grand. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-322307 Share on other sites More sharing options...
June 11, 201014 yr comment_322317 It might actually run okay. They used that manifold on some of the non US Datsun/Nissan sedans with L engines. And a 38 Weber is probably bigger than the carb they used. Edited June 11, 201014 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-322317 Share on other sites More sharing options...
July 3, 201014 yr Author comment_324325 guys this is not a one barrell carb it is a two barrell outlaw 38 weber sure it will win no races but it will drive and thats all i want if any one knows where i can get two more of the 240 K intake manifold's let me know mike Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-324325 Share on other sites More sharing options...
July 3, 201014 yr comment_324342 That is one of the most restrictive(PG description)manifolds i've seen in a long time. Link to comment https://www.classiczcars.com/forums/topic/35653-intake-manf/?&page=2#findComment-324342 Share on other sites More sharing options...
