Posted April 27, 201015 yr comment_317345 Howdy,My drivers door on my 1970 z is starting to be pain, and it seems to be getting worse ;-)I pull open the handle, and sometimes it opens!!! It always works from the inside. Before I tear off the door panel, thought I would get some ideas from you!!!!Any advice is greatly appreciated!!!Thanks,Bob Link to comment https://www.classiczcars.com/forums/topic/35660-drivers-door-wont-open-from-the-outside/ Share on other sites More sharing options...
April 27, 201015 yr comment_317350 When you pull on the door handle, it activate the push rod, the push rod is adjustable (there is a white plastic nut) by turning the nut. Just re-keyed all my locks and adjusted the push rod today. Link to comment https://www.classiczcars.com/forums/topic/35660-drivers-door-wont-open-from-the-outside/#findComment-317350 Share on other sites More sharing options...
April 27, 201015 yr comment_317380 Also the handle can be worn down where the rod attaches. If you switch them side to side you can solve your problem.Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/35660-drivers-door-wont-open-from-the-outside/#findComment-317380 Share on other sites More sharing options...
April 27, 201015 yr comment_317402 Pop said: Also the handle can be worn down where the rod attaches. If you switch them side to side you can solve your problem.Cheers' date=' Mike[/quote']The help me section at the auto parts store has a similar connector for this part Link to comment https://www.classiczcars.com/forums/topic/35660-drivers-door-wont-open-from-the-outside/#findComment-317402 Share on other sites More sharing options...
