Posted November 11, 200222 yr comment_18767 I have searched the site for the differential ratio that came on a 71 240 with an automatic transmission. I am planning to remove the auto and install a 5 speed and need to know if should also grab the rear end from the donor.Thanks Link to comment https://www.classiczcars.com/forums/topic/3568-differential-ratio-on-an-automatic-trans/ Share on other sites More sharing options...
November 11, 200222 yr comment_18773 As far as I know all the automatic equipped cars in the US came with a 3.54:1 rear gear. A bit better than the 3.36 manual transmission ratio but not as good as a 3.90 or 4.11 would be with a 5 speed. Link to comment https://www.classiczcars.com/forums/topic/3568-differential-ratio-on-an-automatic-trans/#findComment-18773 Share on other sites More sharing options...
