January 15, 201114 yr comment_342143 NGK heat range tech article Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-342143 Share on other sites More sharing options...
January 16, 201114 yr comment_342347 Dunno... I use B6ES-11 in my '78 (per specs) and also use the NGK inductive wires. I used the same combo on my old '75, for a combined total of 15 years of daily driving. I never had any problems.The most noise-critical component in both cars would have been the stereo. Yes, if I turn up the volume high enough on my current stereo, I can hear a tiny bit of noise, but only if I strain my ears. It's not at all objectionable. On my '75 (which had a cheaper, poor-student-variety stereo), I did have a bit of noise, but I simply installed a choke on the +12 wire, and the problem went away. Your ears will tell you whether there's a problem.Our ECUs are quite primitive and are linear devices. They won't go crazy from electrical noise like the digital ones could. Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-342347 Share on other sites More sharing options...
April 10, 201312 yr comment_420103 IdahoKidd said: On a related note. Any NGK"R" plug I have ever put into any running motor I have had to push home at some point. Everything from my ATV, my dirt and street bike, my snowmobiles, lawn mower, I have had to push home because of plug failure. They fail prematurely and I will NEVER put another R plug into anything I own. I'd put in a champion plug first! Now, a non NGK"R" plug, IF you can find them, are the best! This is interesting, since I got the BPR6ES plugs for my 240. And it ran okay for 3 days, after that it began sputtering on acceleration. I took the plugs out and looked black sooted. I put back the B7ES plugs, and was running strong again. The B7ES also seems to color nice dark white in the middle, while the BPR6ES turns all sooted? Weird stuff... I must admit, I'm not a fan of modern plugs in old cars.. The BPR6ES says made in france, the B7ES made in japan.. maybe it just hates France Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-420103 Share on other sites More sharing options...
April 30, 201312 yr comment_421976 bartsscooterservice said: This is interesting, since I got the BPR6ES plugs for my 240. And it ran okay for 3 days, after that it began sputtering on acceleration. I took the plugs out and looked black sooted. I put back the B7ES plugs, and was running strong again. The B7ES also seems to color nice dark white in the middle, while the BPR6ES turns all sooted? Weird stuff...I must admit, I'm not a fan of modern plugs in old cars.. The BPR6ES says made in france, the B7ES made in japan.. maybe it just hates France The B7ES is a different heat range would attribute the difference of plug condition to this than country of origin! Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-421976 Share on other sites More sharing options...
September 16, 201311 yr comment_431807 Well, Ive got the same questions...FSM says B6ES-11....NGK site says BR6ES-11 and advance parts says they are disc and wants to sell me BPR6ES-11....confusion for the rank amatuer.....thanks for the link to NGK that was educational Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-431807 Share on other sites More sharing options...
September 16, 201311 yr comment_431808 so where do you get the B6ES-11? Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-431808 Share on other sites More sharing options...
September 16, 201311 yr comment_431813 Amazon: Amazon.com: ngk B6ES-11 Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-431813 Share on other sites More sharing options...
December 27, 201311 yr comment_438567 My experience with my 71 was interesting. BP6ES always worked fine over decades. When I changed spark plug wires to copper I had massive radio static which I eliminated with Volkswagen Beetle spark plug boots, They screw into the wire and have a resister in them. This eliminated the static and I never had a problem with them and they didn't effect the performance in any way.Good LuckMark Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-438567 Share on other sites More sharing options...
January 20, 201411 yr comment_439959 The P in "BPR" means it has a projected tip. The ceramic tip is longer than non "p" plugs. If you are using NGK wires they also have noise suppression built in. Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-439959 Share on other sites More sharing options...
January 20, 201411 yr comment_439978 Tech Service Bulletin TS71-21 issued 3/30/71 changed the spark plug spec in L24s to BP6ES applicable to current production as well as earlier engines. Reason given was a wider heat range for plugs with projected tips.The R added to the number indicates an internal resistor to suppress radio static. Not required if your high tension leads incorporate resistors. Link to comment https://www.classiczcars.com/forums/topic/35712-bp6es-v-bpr6es/?&page=2#findComment-439978 Share on other sites More sharing options...
