Email logins are now active ×
help
81 280zx
Yes, I could tell it was a 240Z from the VIN. The engine number is only shown on the data plate from '70-77 cars.
If you have the VIN entered correctly here, that is a '70, not a '71.
Hi, Arne, "long time no see." I agree with everything you have said above.
May I please add that the car appears to be an early 4/71 build, since it falls
into the range of 02781 to 03486 that I have established so far. But as for
the originality of the ENGINE, you have already stated correctly that the
only reasonable way is to match its S/N with that on the data plate on the
R/F strut tower. I think I am safe in saying that the S/N of the engine
NEVER matches the VIN of the chassis; it is always a little higher. Of
course if someone has found the engine in another car that does match the
VIN of his car, and done a swap, that would negate the word "NEVER."
This may be as good a time as any to ask whether anyone knows what
happened to the first 2000 or so L-24 engines? And what happened to
other engines that seem not to have found their way into cars? The
spread between VIN and engine S/N widens with time. Examples:
HLS30-00016, engine L24-02079 (Jim Frederick's car, lowest known
S/N of an engine still operational in a Z Car) (diff. of 2063)
HLS30-00013, engine L24-02085 (diff. of 2072)
HLS30-00171, engine L24-02311 (diff. of 2140)
HLS30-06289, engine L24-009625 (diff. of 3336)
HLS30-86105, engine L24-108801 (diff. of 22696)
SOME could have been determined by QC to be too defective to release
right at the factory, but we know that around 500 were installed and
released between 9/69 and 11/69.
We know that the crank harmonic problem curtailed production during
12/69, but very few were released while that was being rectified.
I was involved with Z Cars virtually from the beginning, but never heard
of any Z Cars having a complete engine replaced as a "repair part," nor
of any Datsun dealer keeping complete L24 engines in the Parts Department
inventory.
Perhaps the engine serial numbers began with #2001, or 2079, or some
number other than 0001 for some reason unknown to us.
So, this disparity continues to baffle me to this day. Maybe some of
our Z friends who know more about this than I do, could help me?
All Z Best,...............................Kathy & Rick
Thank you all for your timly response. The block matches the engine! The original head is missing though. What heads do you folks suggest I purchase.
This is an original restorastion. Also is there a good short block rebuild kit?
Edited by 81 280zx
  • Who's Online   1 Member, 0 Anonymous, 611 Guests (See full list)
