Rear brake problem and stiffness of pedal
Reverend
Ok i recently bleed the brakes from my 72 and that made front brakes work. Yesterday i lifted car up and hit the brakes while rear wheels were spinning. No effect. So could this be problem in the pressure regulator in brake lines?
My buddy was bleeding the rear and i think there were no brake fluid coming from bleed nipple, he's even more newbie than i so..
Is it possible that the brake pedal stiffnes is caused by the same problem? It barely moves when i press it with full power, before bleed it was movable (well the brakes didn't work then at all)
As i said before, despite that brake pedal is almost impossible to move, front brakes work fine.
Thanks already.
Your brake pedal will only move what the pads will allow, you can try to loosen the brake line before the brake cylinder to see if there is any fluid coming out, bleed your brakes before the brake cylinder.
I couldn't get it off without doing any damage so i let the valve alone for a while..It was stuck in the hard lines. Is this part somehow related to my braking problems? In other thread there were some discussion about this part. I think it belongs inside master vac..? (dont mind about that broken steering wheel cap)
Brake pressure differential switch.
If there's a pressure different of about 200psi between the front and rear brakes when the brake pedal is applied the shuttle valve in the switch will cut off brake fluid flow and pressure to the low pressure side. If the S30 brake system is not full of fluid, you must gravity bleed the front and rear brakes before pushing on the brake pedal.
Gravity bleed is just that, no pushing pedal, just open the bleeder at the driver's rear (longest run from what I've learned) and let the fluid leak out. Make sure you keep an eye on the master's fluid level and keep it topped off. When you get a flow of fluid thru the bleeder for a while, shut it off. Move to the passenger's rear and repeat the process. This should fill the lines with fluid and resolve the problem.
Had to do this when I replaced the driver's rear hard line.
At that point, bleed the brakes normally with pedal movement. Driver's rear first and then pass rear.
Edited by mlc240z
  • Who's Online   1 Member, 0 Anonymous, 334 Guests (See full list)
