I think yes.I saw one at a show once.Of course you have to use 260 interior arm rest and such.Sorry I can't be absolute.I would find it hard to believe that datsun retooled the assembly line for a door panel.
https://www.classiczcars.com/forums/topic/3592-door-panels/#findComment-18921
This is a perfect example of why you need / want to get the Parts Microfiche that is for sale here.
By looking up the individual models you can readily compare the part number. If they're the same, then bingo, they'll work.
The first part of the part number is the same, what seems to change is the suffix, which is the color code.
You may find that as Daniel pointed out that some of the other parts also have to be changed to accomodate the different year panel.
If you're changing the panel due to availability, be aware that you CAN get the correct ones for the early years.
Hope this helps, but do yourself a favor, get the CD from Mike here, it's definitely worth it.
2¢
https://www.classiczcars.com/forums/topic/3592-door-panels/#findComment-18935
