Posted May 22, 201014 yr comment_320517 I've just had the stock L28 out of my '76 280Z rebuilt. It had to get punched out by 30 thou, and the dished pistons were discarded in favor of flat-tops. Can anyone tell me what the CC's on the stock pistons would have been, or even just tell me what my new displacement and compression ratio should be? I guess I'm also going to have to figure out what kind of timing to run with the new compression ratio. I was using premium fuel before, and now I'm going to need it for sure. Link to comment https://www.classiczcars.com/forums/topic/35969-displacement-after-rebuild/ Share on other sites More sharing options...
May 22, 201014 yr comment_320519 The piston dish will not alter your displacement. Your displacement is the (new bore area) x (the piston stroke) x 6Compression has changed. You can calculate all of it here:http://www.atlanticz.ca/zclub/techtips/calcs/engine%20builder/index.html Link to comment https://www.classiczcars.com/forums/topic/35969-displacement-after-rebuild/#findComment-320519 Share on other sites More sharing options...
May 22, 201014 yr comment_320520 Stock was 86mm bore and 79mm stroke. This gave 2753cc displacement.You now have a bore of 86.75mm. Running it through the calculator gives me a new displacement of 2802cc.As for the compression, what head, and has it been shaved at all? Link to comment https://www.classiczcars.com/forums/topic/35969-displacement-after-rebuild/#findComment-320520 Share on other sites More sharing options...
May 22, 201014 yr Author comment_320521 Thanks for the replies. It's a stock N42 head, stock height Fel-Pro gasket. I didn't realize the dish of the piston would not factor into overall displacement.Here's what the calculator spat out, after I added the overbore:Block Height= 207.87 mmDeck Height= -0.07 mmChamber Volume= 44.6 ccCylinder Volume= 458.9 ccGasket Volume= 7.86 ccDish Volume= 0 ccDeck Volume= 0.41 ccUncompressed Volume= 511.35 ccCompressed Volume= 52.87 ccCompression ratio= 9.67:1Total displacement= 2753.37 ccA different calculator I found today gave me a compression ratio of 9.975:1... may as well say 10:1. Have to be a little careful with the fuel and the timing I think. The bottom end looks stout enough, anyway, and I put in the good ARP fasteners with the rebuild. Now can anyone tell me what the new HP should be? Link to comment https://www.classiczcars.com/forums/topic/35969-displacement-after-rebuild/#findComment-320521 Share on other sites More sharing options...
