I have a newbie question. As stated in a previous post, I am trying to put my engine on a stand. I want to repaint the block and work on cleaning it up prior to having it rebuilt. The problem is, the clutch needs to be removed before the engine can connect to the stand. How does the clutch come off? Is there a special tool or technique involved? Thanks.
carl
https://www.classiczcars.com/forums/topic/35974-clutch-removal/
take off the pressure plate.. it will fall out
might want to rethink the order though - if you are getting it rebuilt, you might want to do that after..
Oh, you will need the alignment tool to put it back on..
Edited by lbpdz
forgot to mention the alignment tool
Just unbolt the six or eight bolts that hold the pressure plate to the flywheel. The clutch alignment tool is fairly cheap and available from MSA, Nissan, etc. I know that there are people in the Indy Z car club who could loan you one... Like me for example.
