Posted May 23, 201014 yr comment_320564 any tricks or ideas on fixing a leaking door seal. It leaks at the bottom back corner of the door, or is it a better idea to just replace it. Link to comment https://www.classiczcars.com/forums/topic/35975-stop-a-leaking-door-seal/ Share on other sites More sharing options...
May 23, 201014 yr comment_320565 How old is the door seal? If it is original, or fairly old try replacing it first. If it is relatively new, you might try adding some home weather striping to the inside of the door to "assist" with the seal. Link to comment https://www.classiczcars.com/forums/topic/35975-stop-a-leaking-door-seal/#findComment-320565 Share on other sites More sharing options...
