Posted May 29, 201014 yr comment_321027 When i bought my z it came with an L26 swap and a early 5 speed tranny but now clutch is going bad and i dont know what clutch do i need to use 240z,260z or if i can use a 280z/zx non turbo clutch? please if any one can help! Link to comment https://www.classiczcars.com/forums/topic/36029-clutch-in-a-l26early-5speed/ Share on other sites More sharing options...
May 29, 201014 yr comment_321036 The clutch is the same for all the non turbo cars and 2+2's. (Turbo cars and 2+2's have a larger diameter). Different manufacturer's make clutches to different specifications for specific needs and applications, but a relatively stock motor doesn't require anything more than a stock type clutch. You can get them at O'rielly's, Ebay, Napa, most anywhere, for around $120 +/-. Get the entire kit, clutch, pressure plate, throw out bearing as a set and you will be fine. Remember to resurface the flywheel or you are likely to be wasting time and money. Do a search for "clutch" and you will find pages of information right here at this site. Link to comment https://www.classiczcars.com/forums/topic/36029-clutch-in-a-l26early-5speed/#findComment-321036 Share on other sites More sharing options...
May 29, 201014 yr comment_321037 Match the bearing collar to the clutch........240z collar to 240z clutch........280z collar to 280z clutch etc. Link to comment https://www.classiczcars.com/forums/topic/36029-clutch-in-a-l26early-5speed/#findComment-321037 Share on other sites More sharing options...
May 30, 201014 yr Author comment_321081 well thankz for all your help i think now is ebay time to search for a new clutch Link to comment https://www.classiczcars.com/forums/topic/36029-clutch-in-a-l26early-5speed/#findComment-321081 Share on other sites More sharing options...
