I don't have a picture just yet, but there are two circular holes, both in slightly raised squares of metal on either side of the spare tire bowl on the floor of the trunk. Do I need grommets for those holes? I dug through MSA trying to guess what they might be called but didn't find anything obvious.
Here's a picture, the hole is at the lower left. The raised squares of metal are actually flat metal with raised insulation around them, that was my own faulty memory at work. I can touch the top of the gas tank through them.
