Posted June 3, 201014 yr comment_321481 How can I disconnect the little plastic swivel joints in the throttle linkage to the carbs on a 1971 240Z?Do they pop off or ?Don't want to break them ... thanks! Link to comment https://www.classiczcars.com/forums/topic/36074-how-can-i-disconnect-the-throttle-swivels/ Share on other sites More sharing options...
June 3, 201014 yr comment_321482 They pop off. Use a screwdriver to wedge them off. Unless they're unduly brittle, they won't break. Link to comment https://www.classiczcars.com/forums/topic/36074-how-can-i-disconnect-the-throttle-swivels/#findComment-321482 Share on other sites More sharing options...
June 3, 201014 yr comment_321496 Hose them with some type of lube first. Link to comment https://www.classiczcars.com/forums/topic/36074-how-can-i-disconnect-the-throttle-swivels/#findComment-321496 Share on other sites More sharing options...
June 3, 201014 yr comment_321498 Do not use a screw driver. Turn/twist the cap into the rod until it pops off. The screw driver could deform or crack the head of the cap. Link to comment https://www.classiczcars.com/forums/topic/36074-how-can-i-disconnect-the-throttle-swivels/#findComment-321498 Share on other sites More sharing options...
June 3, 201014 yr comment_321506 I should have been more clear. The screwdriver should not contact the plastic, but used to pry against the rod adjacent to the plastic. My error. Link to comment https://www.classiczcars.com/forums/topic/36074-how-can-i-disconnect-the-throttle-swivels/#findComment-321506 Share on other sites More sharing options...
