Posted June 14, 201014 yr comment_322505 Car: 1978 Datsun 280Z fully stock. Great condition.Problem:When I first start the car and engage my clutch it makes a very high pitch squealing sound. It only lasts for like my first few gear changes (first 5-15 seconds - maybe not even that.) After that it's fine. My friends were guessing it was my e-brake. But I know its down? I know my Parking Brake IS down. But are E-brakes known know to stick? The car is drivable but when I hear the sound I die a little on the inside because I know my car is hurting...Help! All comments welcome. Edited June 14, 201014 yr by Daishi_GD Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/ Share on other sites More sharing options...
June 14, 201014 yr comment_322507 If the noise is when you push the clutch, the noise could be the clutch release bearing. To fix this,the gearbox needs to come out--- Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322507 Share on other sites More sharing options...
June 14, 201014 yr Author comment_322509 If the noise is when you push the clutch, the noise could be the clutch release bearing. To fix this,the gearbox needs to come out--- Clutch in/ out didn't make a difference I think. I think pressing the gas did though. I need to look into it more. My other friend guessed it was one of the belts squealing. Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322509 Share on other sites More sharing options...
June 14, 201014 yr comment_322510 By bet is on the belts being loose. Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322510 Share on other sites More sharing options...
June 14, 201014 yr comment_322515 A bad throw-out bearing sounds like someone replaced the bearings with rocks.Squealing is usually the result of a worn or loose belt. If the belts are tight and show little wear, it could be the alternator itself. Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322515 Share on other sites More sharing options...
June 14, 201014 yr comment_322522 Guys, I would replace the Belts AND while your at it Replace the bearings in the Belt Tensioners. I have like eight or ten of these that I bought in bulk. PM me with your address and they are yours (Just pay for the postage - probably $3-$4 bucks). This is a good 'Pay It Forward' opportunity for me.NOW after that is done, If you still have the squeal, then your looking at the Clutch Throw-Out Bearing, which will have to be another discussion.... Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322522 Share on other sites More sharing options...
June 14, 201014 yr comment_322536 ...Replace the bearings in the Belt TensionersThis must be another one of those areas where the 240 and 280 differ. On the 240, the belt circulates the harmonic balancer, alternator and water pump. Tension is adjusted via the alternator mount. If the 280 uses a separate belt tensionor, that could be the source of the squeal. Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322536 Share on other sites More sharing options...
June 14, 201014 yr comment_322538 This must be another one of those areas where the 240 and 280 differ. On the 240, the belt circulates the harmonic balancer, alternator and water pump. Tension is adjusted via the alternator mount. If the 280 uses a separate belt tensionor, that could be the source of the squeal.Not all 280z's have separate belt tensioners. My 280 had and A/C (which I took off). It just ran off the crank and was adjusted by moving it over on the mount. I took it off and now basically have just one belt to the alt, water pump and crank. It makes sense that that the belt would make the squeeling noise. It is possible that it can be the alternator. It hard to "hear" the noise over then net so I'm just making an educated guess. Jan Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322538 Share on other sites More sharing options...
June 14, 201014 yr Author comment_322544 Took a picture of my belts...or lack of belts. I think its a loose belt - It squeals when I press the gas but has nothing to do with clutch movement. Main concern for me is that I seem to lose power. Edited June 14, 201014 yr by Daishi_GD Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322544 Share on other sites More sharing options...
June 14, 201014 yr comment_322552 Took a picture of my belts...or lack of belts. I think its a loose belt - It squeals when I press the gas but has nothing to do with clutch movement.Main concern for me is that I seem to lose power.By the looks of your picture you have no A/C belt. From what you stated above (or what I got out of it anyway) is that when your car is cold and you start it it makes a squeeling noise. If you seem to be loosing power it could be that either your water pump and/or the alternator bearing is seizing. This is my way of figuring it out. If Z's are anything like all the other cars I've worked on you should be able to run your car without the belt for a few minutes. (or seconds as that's how long you said it lasted). See if you hear the sound with no belt. Jan Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322552 Share on other sites More sharing options...
June 14, 201014 yr comment_322571 A quick and mostly accurate belt tension test is to find the longest run of belt between two pulleys. In the center of that longest run, depress the belt. If you can deflect the belt more than 1/2 inch with moderate hand pressure, it is too loose and needs to be re-tensioned. Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322571 Share on other sites More sharing options...
June 15, 201014 yr comment_322583 Somewhere back in my past I remember someone telling me that it's possible to stop a belt from squealing by rubbing a bar of soap on it. Anyone else ever hear of this? Probably the quickest and easiest test. Link to comment https://www.classiczcars.com/forums/topic/36179-squeeling-whyyyyyyyy~/#findComment-322583 Share on other sites More sharing options...
