Posted May 5, 200024 yr comment_749 Why more is not always better when it comes to the L6:A triple SU carburator setup might work if they are attached to a plenum. If you try to feed individual runners from triple SU (two runners per carb) you'll have trouble making as much power as dual SUs. Why? The firing order of the L6 is: 1 5 3 6 2 4. Keep this in mind while we assume that front SU feeds cylinders 1 & 2, middle SU feeds cylinders 3 & 4, and rear SU feeds cylinders 5 & 6. On a dual SU installation you get an intake pulse to each carb every 240 degrees of crankshaft rotation, and this is evenly spaced. You end up with a pretty even mixture balance between all the cylinders. On a triple SU installation you get an intake pulse on each carb as follows: Front SU: There are 3 cylinders (intake pulses) with 360 degrees of rotation between 1 & 2 and 1 cylinder (intake pulse) between cylinders 2 & 1 with 120 degrees of rotation. This causes an imbalance in the mixture (rich to lean) between cylinders 1 & 2. Middle SU: There are 2 cylinders (intake pulses) with 240 degrees of rotation between cylinders 3 & 4 and 2 cylinders (intake pulses) with 240 degrees of rotation between cylinders 4 & 3. This creates a balanced mixture between these two cylinders. Rear SU: There is 1 cylinder (intake pulse) with 120 degrees of rotation between 5 & 6 and three cylinders (intake pulses) between cylinders 6 & 5 with 360 degrees of rotation. This causes an imbalance in the mixture (rich to lean) between cylinders 6 & 5. I may have my number of degrees off, but I think I've illustrated how it would be difficult to achieve a balanced mixture across all cylinders during one full power cycle (720 degrees of crankshaft rotation) with a triple SU carburator setup using individual runners. Again, if you ran these triples to a plenum and then out to the runner, you could work up some power.----------------------------John Coffeyjohncof@veriomail.com[This message has been edited by John Coffey (edited 05-04-2000).] Link to comment https://www.classiczcars.com/forums/topic/362-triple-sus/ Share on other sites More sharing options...
May 5, 200024 yr Author comment_750 Another post on this topic from Kyle: John- Excellent post, very hard to <snip> down, so here's my attempt at distilling the data: Cyl Deg | f(2x) r(2x) | f(3x) m(3x) r(3x) 1 0 | 0 - | 0 - - 5 120 | - 120 | - - 120 3 240 | 240 - | - 240 - 6 360 | - 360 | - - 360 2 480 | 480 - | 480 - - 4 600 | - 600 | - 600 - John's point becomes very obvious when you look at the "-" in the chart; on a double carb (2x) setup, there's a pulse to each carb every other cylinder in the firing order. In a triple carb setup (3x) the pulses are not even, except for the middle (m) carb. A very interesting point, to be sure. Seems that there was someone around that ran triple SUs, was it Preston? I'd be interested in hearing what was done to work around this issue. A balance tube might do it, but I'd guess that the stock type tube would be too small. And if you have to run a common manifold (plenum), you'll get into the same problem as with four bbl manifolds - long intake path, fuel puddling. The rear carb in a triple setup would effectively feed the other cylinders in the "dead" space between #6 and #5, for example. With a dry-flow MPEFI setup, this might not be as big a deal..... but then again, why not just run a larger, single throttle body? Hey! All you have to do to make this work is change the firing order! A new cam and crank, and you're set! <> Looks like 1,5,3,6,2,4 might do it. 'Course, then the famous L6 smoothness would go bye-bye;-) Hmm... let's dig my grave a little deeper here... at 1000RPM, you have 3000 intake pulses per minute, right? If that's right, then you have an intake pulse every .02 seconds, on a 2x setup. That means that each "-" in the chart above is equivalent to a .02 second dead spot in the intake flow. (jeeze I hope this is right;-) Going further, that means that the biggest dead spot in a 3x setup would be .06 seconds. And that's AT IDLE. At 3000RPM, there'd be 9000 pulses, one every .0067 seconds, the worst dead spot would be .02 seconds. Does this mean that a 3x SU setup would be as smooth as an idling 2x setup? And mightn't velocity stacks or longer intake runners take care of this? Bench engineering is almost as much fun as bench racing! Kyle Link to comment https://www.classiczcars.com/forums/topic/362-triple-sus/#findComment-750 Share on other sites More sharing options...
May 5, 200024 yr Author comment_751 Another post on this topic from Marc Sayer (I think he sent this out a couple years ago):From: Marc SayerSubject: Triple S.U. Setup - not so good.Well I see I really opened up a can of worms with this. Before peoplestart going out to buy up triple SU bits, let me run this down for you soyou understand what's up. With the dual SU manifold the air / fule distribution is poor because therunner lengths are different. Datsun worked their butts off to try andcompensate for this and really did a pretty good job (you should see howbad some of the British stuff is). The advantage of the dual manifold isthat the pulsations come in even periods. Let me try to put this visually; 1--- 2------- 103020103020 / 3---/A "0" represents a "dead" time slice, a time when none of the cylindersfed by this manifold are in the intake phase. Any other number indicatesthe cylinder which is in the intake phase. 4--- 5------- 050604050604 / 6---/As you can see the pulse pattern is very even, being one time slice on, thenone time slice off. This means that each cylinder is pulling on a column of air/fuel (what iscontained in the manifold) with about the same velocity, because eachcylinder is preceded by the same length of "dead" time in the manifold.This promotes all sorts of positive effects, and keeps air speed in themanifolds fairly constant. It limits the amount of "flow reversal" that cantake place by limiting the length of "dead time" in each manifold. Theseeffects are mitigated to some degree by the differences in individualrunner lengths and by the distances from the main plenum of each manifoldto each intake valve. But all in all this manifold and firing order do workfairly well together. Now here is the pattern for a triple SU set up; 1-- --- 100020100020 2--/ 3-- --- 003004003004 4--/ 5-- --- 050600050600 6--/You can see from this that the front and rear manifolds have unevenpulsations. 3 time slices off, 1 on, 1 off, 1 on. This means that the cylinderthat opens after the 3-time-slices-off "dead" period, will be pulling on amuch slower column of air/fuel than the other cylinder will. This will cause those cylinders (#'s 2 & 5) to run a little leaner and theircounterparts (#'s 1 & 6) to run a little richer. The reason for this is thatair reacts to changes in velocity more quickly than the fuel does. Since the air/fuel mix in the manifold has 3 time slices to slow downbefore cylinders 2 & 5 draw on it, it will be slower for them and as ittries to speed up again, the air will respond more quickly and get to thecylinder slightly sooner that the fuel. By then the intake stroke for thesecylinders will be ending, the extra fuel meant for these cylinders willstack up in the manifold and then cylinders 1 & 6 will open. They will be opening to a fast moving, extra rich, mixture. (On some 4 cylmotors this phenomenon is so bad that the engine idles on only two of thecylinders if the mixture is not within range). The center manifold is different, however, its pulsation pattern is even,with 2 off time slices followed by 1 on time slice. each cylinder will bepulling on a column of air/fuel with about the same velocity, butthatvelocity will be fairly low due to the fact that twice as much time isspent "off" as is spent "on". So the triple SU manifolding has three basic problems; First, the pulsing patterns are not the same for all manifolds and, Second, the outer manifolds will have distribution problems caused byuneven pulse patterns and, Third, the center manifold will suffer from reduced velocity. The third problem is the least important of the three and is true fortriple Mikuni's as well (in fact they suffer from a 5:1, off to on, ratio). Iwould not be concerned about this except as it relates to the behavior ofthe outer manifolds. The solution for the outer manifold's distribution problems is probablygoing to be similar to what was done for the British 4 cyl, siamesedengines. The runners of the manifold were "aimed" at the lean runningcylinders slightly. This helped to overcome the distribution bias that wascreated by the uneven pulsing. I am not sure how well this would work onthe Z motor, but on MGB's it helped quite a bit. It didn't eliminate theproblem, but it did significantly reduce it. The last problem, that of the manifolds not all having the samepulsepatterns is not soluble except by altering the firing order. But byameliorating the negative effects of this, we can to some degree cancelthe problem out. If the manifolding is done well it will be equal to, or slightly better thanthe stock manifold for distribution, but will increase flow. If runner andplenum size is kept small enough to keep air velocities up, the drivabilityand throttle response should be better than a dual set up. Anyway, there's something for all you triple SU freaks to chew on for awhile. You could solve all these problems by going to 6 of the 1.25" (32mm)SU's you know. :-) Marc Sayer Link to comment https://www.classiczcars.com/forums/topic/362-triple-sus/#findComment-751 Share on other sites More sharing options...
