Torque setting?
According to the Workshop manual the torque setting for the "Transverse link mounting bolt" is 79.6 to 94 ft lbs... I am feeling that this is a lot. Can anyone confirm that this is correct?
Also I need to confirm that this is for the nut that goes on the end of the bolt that has half of the threaded shaft missing that goes thru this bushing (#14 in the picture below when it is installed in the transverse link):
The transverse link (part 16) and the nut to torque is number #18
Do I have this all correct?
Thanks,
Mark
Edited by woytovich
Thanks... I actually didn't replace the bushing.. it didn't want to come out and it seems to be in decent shape so I decided to leave it alone.
Did I make a mistake with that?
Mark
Perhaps, but not as serious a mistake as breaking something trying to get it off.
During reinstall, before I bolted things to the outboard end, I could move the transverse link left/right seeing the rubber bushing flex some. It was not loose, broken or hard as a rock - I got a bit of flex... I think it's ok.
And yes, when I was trying to knock the old bushing out (I don't own a press) I was banging on it pretty good (using a socket sized to line up against the bushing's steel sleeve) and it didn't want to move. I didn't want to deform the transverse link....
So I stripped the nut (and I think the bolt). Am I royally screwed or is there a source for this odd bolt?
Anyone know the thread pitch/diameter on these?
Arrrrggghhhh...
Mark
I made note of the part numbers for these the other day. I need some in the near future also.
Bolt - 54436-E4100
Nut - 08912-84410
Washer - 56114-09400
Try your local Nissan Parts Dealer first.
  • Who's Online   2 Members, 0 Anonymous, 216 Guests (See full list)
