Posted June 20, 201014 yr comment_323100 I've installed Ground Control coilovers on my 72 Z. I set up the car as low as possible for street use. My question is........With the 225-50-16 tires on 16" Panasports, we had to dial in almost negative 3 degrees camber to prevent rubbing on the rear fender lips. I don't want to roll the fenders. Is 3 degrees too much for street use or is that OK? I can go to a smaller tire (205-55-16), but really like the 225-50-16's. Thanks Guy Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/ Share on other sites More sharing options...
June 20, 201014 yr comment_323107 Your goal is handling not appearance so too much is when your inside tread edge wears out too quickly by comparison to the rest of the tread face. I use a pyrometer during autocross events to make sure my suspension settings and tire pressure are good. If my temps are close all the way across the tread face the dynamic action of the suspension is flattening out the tire so my settings are good.My guess, 3 degrees is just a little too much for the street. 2 - 2.5 is probably better. Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323107 Share on other sites More sharing options...
June 20, 201014 yr comment_323132 I cut something 1.5 to 2.0 mm out of the fender lip instead of rolling them. With some camber, 0.5 mm 1.0 mm will go a long way! Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323132 Share on other sites More sharing options...
June 20, 201014 yr comment_323141 All you need to do is make a series of small cuts (1/2-inch max.) on the inner fender lip and then push/hammer in up into the wheelwell. This will gain you the needed distance for clearance. I run 245/50/16s w/GC coilovers and I suspect my 240 sits a tad lower than yours. I normally set the camber between 2 and 2.5. Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323141 Share on other sites More sharing options...
June 21, 201014 yr comment_323157 I prefer to roll them with a wood baseball bat. I'm sure if you search "rolling fenders" you'd find a how to. I think you'd be leaving a lot of raw metal exposed to start rusting with a bunch of cuts. Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323157 Share on other sites More sharing options...
June 21, 201014 yr comment_323163 jmortensen said: I prefer to roll them with a wood baseball bat. I'm sure if you search "rolling fenders" you'd find a how to. I think you'd be leaving a lot of raw metal exposed to start rusting with a bunch of cuts.The way I see it... Cutting the edge off a piece of sheet metal with a dremmel and a steady hand leaves a tiny line of exposed metal to hit with a QueueTip dabbed with POR. Rolling a fender cracks a bunch of old paint.BTW, I'm running Yokohama ES100 225/50/16 tires as well. Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323163 Share on other sites More sharing options...
June 21, 201014 yr comment_323170 GreenZZZ said: The way I see it... Cutting the edge off a piece of sheet metal with a dremmel and a steady hand leaves a tiny line of exposed metal to hit with a QueueTip dabbed with POR. Rolling a fender cracks a bunch of old paint.BTW, I'm running Yokohama ES100 225/50/16 tires as well.Never had any trouble with cracking paint. Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323170 Share on other sites More sharing options...
June 21, 201014 yr comment_323198 I was trying to convince him to roll the fenders but.... his cars are immaculate and I certainly understand why he doesn't want to cut or roll. Although it reads -3 camber, it doesn't look bad at all. I actually prefer the look. My 510 is probably -3.5 or more. Besides he doesn't put many miles on these cars so tire wear is kind of a non issue. Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323198 Share on other sites More sharing options...
June 21, 201014 yr Author comment_323224 I appreciate everyone's ideas. I think I'll see how these tires wear........then make a decision. Thanks Guy Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323224 Share on other sites More sharing options...
June 22, 201014 yr comment_323255 I forgot to mention I coated the inside well with POR15 and then sealed it with FG resin. No water of any kind finds it way to those small cuts.... Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323255 Share on other sites More sharing options...
June 22, 201014 yr comment_323275 Diseazd said: I appreciate everyone's ideas. I think I'll see how these tires wear........then make a decision. Thanks Guy I'm predicting you set it at 3.0 and love it! Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323275 Share on other sites More sharing options...
June 22, 201014 yr comment_323296 I'll go ahead and predict corded insides and nearly new outsides. 3 degrees is a lot of neg camber for the street. 5&Dime ought to slot his rear crossmember and dial some of that out. Link to comment https://www.classiczcars.com/forums/topic/36249-how-much-negative-camber-is-too-much/#findComment-323296 Share on other sites More sharing options...
