Email logins are now active ×
L24 Main Bearings Cap and Oil pump pickup
Panamared
I am pretty sure they do as main bearing clearance never changed on the l6 cranks. Let me look up journal sizes in the fsm and i will post back.
Regardless your gonna need a line bore in there or your gonna have to play musical caps till the crank turns freely.
Hi yetterben.
Can you post pictures of the parts. I also need two connecting rod 9mm nuts just in case you have them.
Are you located in United States, because my brother lives in florida and is easy to send him the parts.
Thank You
