Posted June 24, 201014 yr comment_323545 Hi Z fellows.Help me plz.I need the main bearings caps and oil pump pickup for my L24 block.Anyone knows where can I get them.Thank You. Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/ Share on other sites More sharing options...
June 24, 201014 yr comment_323548 I have caps and pickups from a l28 dunno if they fit sure they do. With the main bearing caps though they where block and crank and location specific. Meaning if you get new caps your gonna need a line bore. Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/#findComment-323548 Share on other sites More sharing options...
June 24, 201014 yr Author comment_323572 Hello yetterben.Im not sure if they fit either. Let`s see if someone can drive me the right adress.Thank You. Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/#findComment-323572 Share on other sites More sharing options...
June 24, 201014 yr comment_323573 I am pretty sure they do as main bearing clearance never changed on the l6 cranks. Let me look up journal sizes in the fsm and i will post back. Regardless your gonna need a line bore in there or your gonna have to play musical caps till the crank turns freely. Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/#findComment-323573 Share on other sites More sharing options...
June 24, 201014 yr comment_323574 Journal sizes are the same. Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/#findComment-323574 Share on other sites More sharing options...
June 25, 201014 yr Author comment_323674 Hi yetterben.Can you post pictures of the parts. I also need two connecting rod 9mm nuts just in case you have them.Are you located in United States, because my brother lives in florida and is easy to send him the parts.Thank You Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/#findComment-323674 Share on other sites More sharing options...
June 25, 201014 yr comment_323683 I don't have the 9mm nuts. Here is a pic. I sent you a private message with payment and shipping details. Shipping to Florida not a problem. Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/#findComment-323683 Share on other sites More sharing options...
June 26, 201014 yr comment_323715 I am trying to reach you on msn as well. Link to comment https://www.classiczcars.com/forums/topic/36283-l24-main-bearings-cap-and-oil-pump-pickup/#findComment-323715 Share on other sites More sharing options...
