Posted June 26, 201014 yr comment_323770 Could anyone tell me if I can switch a dual point dist. for a single point dist. and if I did how much work would be involved. Thanks Rob Link to comment https://www.classiczcars.com/forums/topic/36302-dual-pickup-distributor-to-single-1971-240/ Share on other sites More sharing options...
June 27, 201014 yr comment_323785 The dual point distributor was used in the automatics for emissions reasons, at least the STOCK dual point dizzy. Check this thread for more information:http://www.classiczcars.com/forums/showthread.php?t=1747&highlight=dual+point+dist Link to comment https://www.classiczcars.com/forums/topic/36302-dual-pickup-distributor-to-single-1971-240/#findComment-323785 Share on other sites More sharing options...
June 28, 201014 yr Author comment_323939 I checked the thread and thanks for the direction, but I have a standard trans. so the dual point dist. is not stock. I only have one wire running to the dist. so if I find a single point dist it should work? I am leaning towards the protronix but I checked and dual point dist. is not available. thanks Link to comment https://www.classiczcars.com/forums/topic/36302-dual-pickup-distributor-to-single-1971-240/#findComment-323939 Share on other sites More sharing options...
June 28, 201014 yr comment_323945 Find 280Z/ZX dizzy and go with that.Points belong in a museum un-less it's a 100 point car.Pertronix is inferior to the factory electronic distributors. Link to comment https://www.classiczcars.com/forums/topic/36302-dual-pickup-distributor-to-single-1971-240/#findComment-323945 Share on other sites More sharing options...
