Posted June 27, 201014 yr comment_323829 I have discovered leaking coolant coming from the heater core hoses. Do I need to drain the coolant to replace these hoses? Any other hints would be appreciatedThanks Link to comment https://www.classiczcars.com/forums/topic/36308-leaking-heater-core-hoses/ Share on other sites More sharing options...
June 27, 201014 yr comment_323835 I have discovered leaking coolant coming from the heater core hoses. Do I need to drain the coolant to replace these hoses? Any other hints would be appreciatedThanksYes, you have to drain the cooling system. Well, actually the choice is to drain the system INTENTIONALLY, or to pull the hoses off first and take a bath in antifreeze. Personally I prefer the former. Link to comment https://www.classiczcars.com/forums/topic/36308-leaking-heater-core-hoses/#findComment-323835 Share on other sites More sharing options...
June 27, 201014 yr comment_323844 Or use a pair of vice-grips, one on each hose.Problem is that many of these hoses are ancient and the vice grips may crack what you have.Like Walter says, drain it first. Even then you'll have some spillage onto the floor, so keep some rags handy.E Link to comment https://www.classiczcars.com/forums/topic/36308-leaking-heater-core-hoses/#findComment-323844 Share on other sites More sharing options...
June 27, 201014 yr Author comment_323848 Thanks for the advice. Colin Link to comment https://www.classiczcars.com/forums/topic/36308-leaking-heater-core-hoses/#findComment-323848 Share on other sites More sharing options...
