Posted June 29, 201014 yr comment_324044 Hey so I don't know that much about cars so don't kill me if this Q is dumb.I was wondering what the benefits of switching out my SUs with triple weber carbs. What are advantages and disadvantages. any help would be great thx. Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/ Share on other sites More sharing options...
June 29, 201014 yr comment_324047 Fuel economy goes down the tank if setup for performance. Top end increase in power is the reward. Triples will always look and sound better than SU's. The purist people will yell and scream but no denying datto themselves used mikunis in there market......... Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324047 Share on other sites More sharing options...
June 29, 201014 yr comment_324049 If you're anywhere close to Salem I'd invite you to come by the shop and experience what a correctly done set of SUs can feel like. You can take it from there.I'm waiting to see if anyone responds about the costs involved to get those triples dialed in...... Bueller........ anyone........ Hmmmm. Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324049 Share on other sites More sharing options...
June 30, 201014 yr comment_324104 Decent set of triples with Manifold and linkage....... $1500 averageRebuilt Set from ZTherapy, bolted to your stock manifold and linkage...... $630 + Core ( Core is $150 if you don't send them yours)SU's... Barely any TuningTriples... Tuning X3. Wide band O2 meter, Dyno Tuning is better for peak performance, etc, etc..... I'll let Yetterben fill ya in on the specifics.If the Triples were used and off a well tuned motor (already tuned and ready to go) then you're in luck.Just go with the SU's. BEST damn thing I ever did to my 70' 240Z. Thanks Bruce and Steve.Dave Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324104 Share on other sites More sharing options...
June 30, 201014 yr comment_324113 SUs are great, but everything comes with its pros and cons. The SUs are easy to play with as long as the throttle shafts don't leak, but they leave some performance and tunability on the table. The Webers are more expensive, but you can tune them in much more detail. This assumes that one understands both systems well.I got a decent set of Weber triples for $600 complete including manifold and linkage. The deals are out there if you explore classifieds enough. I've seen quite a few recently in that price range, in varying condition.Also, don't slap parts on without thinking. You need to think about what you need in terms of what the car will be used for. Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324113 Share on other sites More sharing options...
June 30, 201014 yr comment_324130 Triples will always be better why.......endless tuning possibilities. I have driven in a car with hogged out SU's that where properly tuned and they do drive good. But they dont offer the hammer of god sound triples do when at wot. Let alone the crescendo you hit at 5 grand. Let alone dogs and people running from the car as you drive buy....i could go on. Triples are just plane fun. I'm waiting to see if anyone responds about the costs involved to get those triples dialed in...... Bueller........ anyone........ Hmmmm. Yes if you have no real base line it can get spendy. But most of the guys out there with 700-1000 in jets etc could have saved themselves loads of money and time buy getting a wb02. But if you are using cost to to say Su's are a better choice that's like comparing a yugo and a 240 You cant negate the fact that the factory used what in its racing teams? So for balls to the wall power choose wisely. No way a set of su's can even be the same as 6 34mm gaping holes into the valves. Just not gonna happen from flow characteristics alone. I will add that if you are a lathe master an can turn your own needles SU's could be dialed in really well i suppose. Bruce has a good product but like anything it has its limits. In summery you need to decide what your car is for if its for dd and occasional abuse get the su's If its for track use or heavy high speed use triples. Su's don't belong on the track or in competition unless its a spec vintage class. As far as the track is concerned bring the su's on over to road America and lets put it to the test. Edited June 30, 201014 yr by yetterben Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324130 Share on other sites More sharing options...
June 30, 201014 yr comment_324133 Road America 2010 Runoffs E Production Z #82 will be there this fall with SUs. Check it out.In fact this car has a double national in Portland this coming weekend. Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324133 Share on other sites More sharing options...
June 30, 201014 yr comment_324134 Bruce i will be there that weekend as well. But like i said its required he have them.....its a production class. I really love that you guys mod the Su's but can you say you can outflow the triples. What about intake design. Cannon, Mikuni, Datto comp, FET, Kameri etc.....I will add this to this thread. Any stock l series inline 6 here yah go for a baseline. F11 e tubes 55f9 idles 135-140 mains 190-210 air correctors. 0 bleed back in pump jet well. 4.5 aux venturi's 200 needle. Mains and correctors vary on choke size. Edited July 1, 201014 yr by yetterben Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324134 Share on other sites More sharing options...
June 30, 201014 yr comment_324149 I guess I see those 2 Hitachis powering the race car down the front straight at Portland at around 140 mph and wonder how many daily driver types are going to see the sunny side of that. That's, give or take, 8 grand. "I drive 11/10ths all the time" is what I hear some guys trying to float. Then again our basic customer will own up to something a little more realistic in terms of the trip to the grocery store maybe isn't a timed event........ Without forced induction of some sort, SUs, Webers, Hollys, etc are only going to supply as much air and fuel as the engine is going to draw..... The infernal combustion engine is afterall nothing more than an air pump.Cheers Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324149 Share on other sites More sharing options...
June 30, 201014 yr comment_324150 Point taken. Its a personal preference and i just happen to be in the triple camp is all. Nothing wrong with your product. Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324150 Share on other sites More sharing options...
July 1, 201014 yr comment_324189 Hey so I don't know that much about cars... Based on the first line of the OP's question, there is NO WAY I'd recommend triples. They sound fantastic and can be made to run great, but they are magnitudes harder to tune than SUs even for the experts. Do yourself a favor and take Bruce up on his invitation to visit his shop. Spend the money and take home a set of his beautiful SUs. You'll be very happy. Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324189 Share on other sites More sharing options...
July 1, 201014 yr comment_324192 I must have missed that. Indeed triples are not for the faint of heart. Sounds like bruce's SU's is your bag of fun waiting to happen. Enjoy the car, when you start to feel the need for never ending screw turning get some webers. Edited July 1, 201014 yr by yetterben Link to comment https://www.classiczcars.com/forums/topic/36333-carb-replacement/#findComment-324192 Share on other sites More sharing options...
