Just about finished installing my 240z front bumper, replacing the large & heaviy stock 280z bumper. Just need to pick up some nylon spacers for the bumper end bolts tomorrow from lowes. I retapped the end bolt captive nuts to clean up the threads (they are indeed 6 x 1 metric.
Fabricated the new main brackets from 1.5" x 1/8 alluminum stock, drilled & slotted them for a small amount of adjustment, & installed them with new stainless hardware. Drilled 1 new hole for the front of the brackets & utilized the stock rear hole for the back location.
Now, on to the back bumper .... even more fun!
https://www.classiczcars.com/forums/topic/36392-240-bumper-conversion/
Nice job S30driver, You did fine job cleaning up that bumper and fitting it to your 280.
I applaud your efforts.
That looks so much better than the stock bumpers. IMHO
Thank you
and a big thanks for the great deal on the bumpers Terrapin!
I also cleaned up the back of the bumper & applied POR 15 to keep it from rusting there.
It was a fun project with a very satisfying end result.
I used stainless bolts with a nylon spacer & rubber washers for the bumper ends after chasing the threads with a tap. Tough to get to those bolts inside the fender, but do-able. Nice & solid, finished this morning after picking up the washers etc.
Dave, Terrapin Z gave me a great deal on them.
Did alot of prep & cleaning, will probably get them re-chromed this winter.
But they are pretty presentable for now.
  • 9 months later...
  • 4 weeks later...
