Problem with my Gauges
mota z
Hey whats up guys i just bought my car this past Friday its a 76 280z. When I drove it back home I notice that my oil/temp gauge was working. The oil one will move but eventually it goes back and wont move a inch I took the time to take my dash off and made sure the cables were on right but no luck. :ermm:? Idk if their might be a fuse I should check or just replace it?
Hey whats up guys so I still cant get the water temp to work I am guessing I am going to need a new gauge. But wile I was checking the cables to see if they were on right i came across the floor temp cable that was disconnected I plugged it in and now it stays on n wont turn off? I read up on it on the owners manual and it says it turns on when heat levels are abnormal and engine isn't functioning right?
