Posted July 8, 201014 yr comment_324752 hi can any body help me i have a 1978 280z l28 tha starts but does not idle if i let go on the gas pedal dies rigth away Link to comment https://www.classiczcars.com/forums/topic/36414-help-fuel-problems/ Share on other sites More sharing options...
July 9, 201014 yr comment_324774 hi can any body help me i have a 1978 280z l28 tha starts but does not idle if i let go on the gas pedal dies rigth awayDude. You will have to put more effort in to your post to get a good response.Have you tried adjusting the idle screw? Have you checked for vacuum leaks? Link to comment https://www.classiczcars.com/forums/topic/36414-help-fuel-problems/#findComment-324774 Share on other sites More sharing options...
