Restoration of inner fender Splash Shield
TomoHawk
I'm about 1/2 finished with the first splash guard.
There was a longitudinal crack at the top of the arch. and a couple cracks at the front, where the bolt is, and near where the headlamp wire goes through.
I first tacked the crack together using GOOP, and then used a cut-up antifreeze jug to form a patch, or backing piece. The patch was heated to the softening point with a heat gun, then placed over the crack, and formed to shape with a dry rag. The patch was then glued on the back of the part so it will not be seen. The patch was oversized to provide strength to the old, thinly-made splash guard.
I will do the same with the crack at the front; you just have to move quickly to get the backing piece to form well to to the splash guard.
Since the clips for the fender arch lip are not available, I will probably use a clip for electronics, such as below.
  • 3 weeks later...
Tomo, he's a spambot from the Philippines. Note the syntax of the post and the cheezy link......
IP Check - 222.127.15.250
222.127.15.250 appears in our database 13 times.
Country of origin: Philippines
Date IP address Username Email Address
6/Aug/10 11:01 AM 222.127.15.250 armandjones82 armandjones82 @ yahoo.com
Edited by sblake01
