Posted July 10, 201014 yr comment_324885 74 260Z I was taking the rear rims off ,1 lug nut was super tight,snap.....*How does the rear drum come off?Is there any bolts holding it on? how does the rear wheel stay on if there are no bolts holding it? ..Thanks Link to comment https://www.classiczcars.com/forums/topic/36431-broken-lug-nut/ Share on other sites More sharing options...
July 10, 201014 yr comment_324888 Rear drum just comes off. There are no bolt. MAKE SURE YOUR HAND BRAKE IS DOWN!If it's stiff - Just turn it as you pull straight towards you. 260zinsd said: how does the rear wheel stay on if there are no bolts holding it?Wait...What? Link to comment https://www.classiczcars.com/forums/topic/36431-broken-lug-nut/#findComment-324888 Share on other sites More sharing options...
July 10, 201014 yr comment_324924 it will be rusted get a large sledge and hit the drum on the corner as hard as you can it will take it mike Link to comment https://www.classiczcars.com/forums/topic/36431-broken-lug-nut/#findComment-324924 Share on other sites More sharing options...
July 11, 201014 yr comment_324950 I have seen the aluminum drums split when they were removed too forcefully. Just thought I would mention that. Link to comment https://www.classiczcars.com/forums/topic/36431-broken-lug-nut/#findComment-324950 Share on other sites More sharing options...
July 11, 201014 yr Author comment_324968 Came off easy......I thought the studs were on the drum ..duh.Thanks again.... Walter Moore said: I have seen the aluminum drums split when they were removed too forcefully. Just thought I would mention that. Link to comment https://www.classiczcars.com/forums/topic/36431-broken-lug-nut/#findComment-324968 Share on other sites More sharing options...
